oil on garage floor under rear diff? seal? help...
Old 01-02-2012, 05:49 PM
fordforlife0225
fordforlife0225's Avatar
Default oil on garage floor under rear diff? seal? help...
2002 gt 38,000 miles
pulled it out of the garage today to do some work on the truck and when i went back in i noticed oil spots on the floor under where the rear diff would sit. i drive the car once or twice a week so im concerned that there is a seal back there that may have gone bad, around the where the drive shaft goes in? i lifted it up and look and i could not tell where it was comming from. plug, diff cover, or shaft seal? anyone have any input, thank you in advance.
fordforlife0225 is offline
Old 01-02-2012, 05:59 PM
96meangreengt
96meangreengt's Avatar
Probably the diff cover because I would think if it was the shaft seal it would run down the back of the diff before falling to the ground and you would see the oil .
when you say you coudn't tell where it was coming from was it because there is oil all over the diff area or none at all?
96meangreengt is offline
Old 01-02-2012, 08:24 PM
fordforlife0225
i should have clarified, i couldn't tell where it was coming from because there was oil, dirt, and road grime all in between the diff cover to the shaft. the bottom of the diff was well coated with just black crap. it a clean car all over, and its weird to see this.
Old 01-02-2012, 08:38 PM
96meangreengt
I would get some degreaser and spray all over the diff and wait a day or 2 and check it again. you should be able to tell where to leak is that way.
Old 01-02-2012, 09:20 PM
Andy13186
Andy13186's Avatar
mine was doing the same, i wiped it off though and it seems to have stopped.. if it continues ill get it rebuilt again.
I had mine rebuilt in 2008 with carbon clutch disks and it was good for 3+ years 25k+ miles. May need to have it done again though because it seems to slip only 1 wheel when going right + minor leak.
Andy13186 is offline
Old 01-03-2012, 05:04 AM
fordforlife0225
thanks,
i sprayed it down when i found it so i will keep a close eye on it. im probably going to add some oil and see if iv lost alot too.
Old 01-03-2012, 08:39 AM
uberstang1
Chupacabra
uberstang1's Avatar
The first step with any kind of diff leak is to check and make sure the breather om the rear end isnt clogged. If it is when pressure builds up its gonna push oil past the seals.
uberstang1 is offline
Old 01-03-2012, 12:09 PM
wolverine8490
wolverine8490's Avatar
Yeah, there is a little vent that can get clogged, and if it does, the pressure will build a create a leak. I would also check that first as stated above.
wolverine8490 is offline
Old 01-03-2012, 02:12 PM
Andy13186
Andy13186's Avatar
where on the differential is this breather hole located?
Old 01-03-2012, 06:06 PM
fordforlife0225
second, didnt know there was a breather, where abouts is the location?
Quick Reply: oil on garage floor under rear diff? seal? help...
