97 Cobra vacuum help please!
Old 01-24-2012, 08:44 PM
dsmithwc04
dsmithwc04's Avatar
Default 97 Cobra vacuum help please!
I have been dealing with this for months. I have searched multiply forums and can't find one with the appropriate answer or an answer at all. I have a 1997 Cobra everything pretty much stock. The vacuum from the EVAP purge valve is not plugged in and I smell gasoline in the car with the heat/air on. I am not sure what the PO did and want to make sure it's nice a tidy and correctly routed. I have seen a diagram but that doesn't seam to help me. Can somebody please help me with pictures or something that can help me with the vacuum routing. The car is unsafe as I get a headache after driving too long. THanks!!!
dsmithwc04 is offline
Old 01-25-2012, 12:40 AM
1998Slow 'Stang
1998Slow 'Stang's Avatar
I've got pictures somewhere that could assist with this somewhere.
But the evap hose comes in to the engine bay through the inner fender on the passenger side where your fuel lines come in. Also on that side is some AC stuff, the engine harness connector block thing, and some other stuff.
There should be a vacuum senor solenoid thingy on your engine harness that should have that evap canister hose hooked to it.
Like I said. I have or can take pics in the near future. (however I make no promises, as I am pretty busy the next couple days)
1998Slow 'Stang is offline
Old 01-25-2012, 06:04 AM
uberstang1
Chupacabra
uberstang1's Avatar
Canister in fender>hose to solenoid> hose to sensor> black hose with red stripe to intake manifold port.
uberstang1 is offline
Old 01-25-2012, 09:17 AM
dsmithwc04
dsmithwc04's Avatar
I see the line from the canister - to the solenoid - to the purge sensor- and then nothing is attached to this. Where exactly does this connect to? Here is a picture of my setup. Not sure if anything else there is messed up or hooked up wrong.
<a href="http://s695.photobucket.com/albums/vv317/dsmithwc04/?action=view&amp;current=IMAG0240.jpg" target="_blank"><img src="http://i695.photobucket.com/albums/vv317/dsmithwc04/IMAG0240.jpg" border="0" alt="Photobucket"></a>
http://i695.photobucket.com/albums/v...4/IMAG0240.jpg
Old 01-25-2012, 10:32 AM
uberstang1
Chupacabra
uberstang1's Avatar
Goes To a port on the manifold, somewhere theres an open port or a hose coming off the manifold that needs to attach to that sensor. Judging by the real dirty engine bay and all of a sudden a right white new vacum splice id bet someone was messing with the vacum lines.
Old 01-25-2012, 06:20 PM
dsmithwc04
dsmithwc04's Avatar
Can it plug anywhere into the vacuum lines?
Old 01-25-2012, 06:42 PM
uberstang1
Chupacabra
uberstang1's Avatar
This is one of the lines u want on its own port on the manifold because it puffs gas fumes through it back into the intake.
Old 08-31-2012, 11:28 AM
SVTCobraDude
SVTCobraDude's Avatar
I'm having the same problem but going the other direction with the blk/w red stipe vacuum hose. Does the Blk/w red stripe run into the fender then along side the fuel line? I'm replacing these lines because their dry rotting.....
SVTCobraDude is offline
Old 08-31-2012, 11:33 AM
SVTCobraDude
The blk/w red stripe hose runs alone side the fuel rail and plugs into a port just underneath the throttle body.
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
11-10-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: 97 Cobra vacuum help please!
