noob question (po124)
Like the title says noob question. I recently got a 02 mustang gt with a 4.6. Last weekend i put in a new bbk 78mm upper plenum/throttle body combo and air intake. Car runs good but i got a code on it po124 tps sensor. I changed the sensor but it still is popping up can anybody help me. Thanks for any input.
You have the TPS in wrong. Loosen it up and make small adjustments till the code stops appearing.
OP: P0124 is an odd-ball, "intermittent TPS signal", Ford does not even list it in the 2000-2004 shop manuals.
Check the connector to make sure it's seated properly, then with KOEO check the voltage between the brown/white (+ probe) and gray/red (- probe) wires at the TPS, it should be around 5.0 V.
Then connect the + probe to the gray/white wire and observe the voltage while opening and closing the throttle. It should vary smoothly from 0.5 V to 4.0+ V. Use insulation piercing probes or stick sewing pins through the wires.
I have also heard of the BBK TPS casting/machining issue, though I have not read exactly what it is about it that causes problems...
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
