01 Cobra Sputtering
Old 06-09-2012, 07:32 PM
Justin01cobra
Justin01cobra's Avatar
Default 01 Cobra Sputtering
I have a issue with my 01 cobra. The car has been driving fine up until a few days ago. Ran fine on interstate and as soon as i got off, the car started sputtering. you leave a stop sign in first and it feels like it is hesitant to go but never gets better. almost sounds like the car is drowning. But you can have it in neutral and rev it up and it does just fine. it only does it worse when on a load no matter how small. I put new motorcraft plugs and put new ignition coils and still no help and the computer isnt pulling any codes either. i also ran seafoam too. Any help would be very greatly appreciated! thank you
Justin01cobra is offline
Old 06-10-2012, 05:48 AM
uberstang1
Chupacabra
uberstang1's Avatar
Might be a coil issue, any check engine codeS?
uberstang1 is offline
Old 06-10-2012, 02:58 PM
Justin01cobra
No its not throwing any codes. And i already put brand new coil packs on saturday and didnt help it one bit.
Old 06-10-2012, 11:31 PM
EddyG
EddyG's Avatar
Since you used seafoam. Which cleans injectors and stuff like that. Maybe when you did a lot of build up from the injectors or fuel filter got unclogged and is now floating around causing it to sputter. Don't know if this even could be a cause but just a thought.
Also check all the plugs that plug into the injectors and make sure they are all plugged in good. And not loose.
EddyG is offline
Old 06-11-2012, 07:23 AM
Justin01cobra
Thank you for the information! And i did check them and they were all good and tight. It just doesnt make sense. Its almost doing the same as my 98 cobra i had and i changed plugs and wires and it fixed that problem. But ive done that to this one and it hasnt helped a bit. Im almost wondering if my computer is gone bad. Cause i unplugged my mass air flow sensor while it was running and the check engine light never came on....
11-10-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Dan04COBRA
09-30-2015 11:46 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: 01 Cobra Sputtering
