Want my 2001 GT automatic to run 12's
Old 06-29-2012, 11:09 PM
TD6676
TD6676's Avatar
Default Want my 2001 GT automatic to run 12's
Is it possible to make my GT run in the 12's without nitrous? I have slicks for it.
I was thinking that gears and a chip would help. But I can't see that doing enough. Is a cam a worth while upgrade for the $$$. I have a cat back exhaust, so I figured I get headers and do the whole exhaust.
Ideas please. I'd like to do it as cheap as possible.
Thanks
TD6676 is offline
Old 06-30-2012, 02:04 AM
Boris91
Boris91's Avatar
Gears, tune, bolt-ons, tires, suspension, weight reduction would get you there.
Boris91 is offline
Old 06-30-2012, 06:42 AM
99 GT vert
99 GT vert's Avatar
here is a build thread on how to get 12s for resonable price
https://mustangforums.com/forum/4-6l...et-vid-up.html
99 GT vert is offline
Old 07-01-2012, 12:00 AM
Soldier GT
Soldier GT's Avatar
1st off, are you a decent driver? You could have every bolt on under the sun but if you don't know what you're doing it's not going to happen. GL!
Soldier GT is offline
Old 07-01-2012, 09:42 AM
sonicx
speed'n
sonicx's Avatar
With an auto, you don't have to worry if your a good driver or not. It only matter with a stick. Rather all the OP needs to focus on is the "timing tree" @ the strip. If you have the $$$ go straight for a turbo or S/C set-up. Otherwise if your on a budget: Stall Convert, Cams, shift kit, 4.10's, and LCA's. Will get you pretty close if not there, maybe.
sonicx is offline
Old 07-01-2012, 12:54 PM
Soldier GT
Soldier GT's Avatar
So with a auto there is no technique needed? Just put the car in drive and push the gas when the light turns green... So why is it a guy on you tube with a 11 5.0 (auto) ran a low 14?
Old 07-01-2012, 01:44 PM
boduke0220
boduke0220's Avatar
4.10 gears, slicks, cams, x pipe tune gutted interior and stall should do it
boduke0220 is offline
Old 07-01-2012, 09:24 PM
SXGT
SXGT's Avatar
with auto the transmission is shifting for you.... the real technique is the launch. what is an 11 5.0 ? a 2011 5.0 running 14s? maybe its 4,000 foot elevation track and he spun out a lot?
who knows.
SXGT is offline
Old 07-02-2012, 09:31 PM
My1stGT
My1stGT's Avatar
Cheap wont get you very far. I'm auto with best of 13.05.with a little more fine tuning I expect 12s this year
My1stGT is offline
Old 07-02-2012, 09:49 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
3800 stall, 4.10s, j-mod, mid pipe, tubular front, slicks and a good day of weather and track prep. You can hit 12s without cams or gutting your interior.
WannaBeGearHead is offline
Quick Reply: Want my 2001 GT automatic to run 12's
