New clutch kit issue
07-28-2012, 08:25 PM
I just installed a new clutch kit, have not done this before.
After everything is put back together i find that when I take my foot off the clutch in neutral that I hear high pitch grinding, sounds like threads in transmission fork arent meshing.
I'm starting to take things back apart but I'm not sure what I'm looking for
07-28-2012, 08:46 PM
If you are able to post a video of the sounds the car is making that would help a lot.
07-28-2012, 10:38 PM
Chupacabra
Is your clutch for seated properly on its pivot ball, this can be checked without removing the transmission.
08-05-2012, 03:57 PM
ok still working on this issue
here is the video
www.youtube.com/watch?v=nzBCr7anaPA&feature=em-share_video_user
08-05-2012, 03:58 PM
what is that sound i let off clutch????
08-05-2012, 04:31 PM
Other than very ugly?
It almost sounds like the input shaft splines aren't fully engaging. Are you sure the clutch disk was facing the right way?
08-06-2012, 07:33 AM
Chupacabra
Quote:
Originally Posted by
uberstang1
Did you look at this yet?
08-06-2012, 09:49 AM
uberstang1
Yes I did and it was seated properly, I took the transmission off again and when i did I made sure it was properly greased and seated
The pivot ball just fits in the metsl flange of the ,correct?
08-06-2012, 09:51 AM
Torch_Vert
Clutch disk is in correctly but at this point I
m thinking wrong or defective clutch disk.
The inout shaft not meshing with clutch disk has got to be what the sound is.
08-06-2012, 10:11 AM
Chupacabra
Can you take some pics, is the clutch disk on backwardS?
