Trick Flow Twisted wedge heads
Old 10-08-2012, 07:52 AM
nickpupo00gt
nickpupo00gt's Avatar
Default Trick Flow Twisted wedge heads
I was wondering if anybody had the tfs heads on a 2v and has had them ported and polished, what kind of power did you see as well?
nickpupo00gt is offline
Old 10-08-2012, 04:11 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
why would you want to port them?
sn95_331_GT_ yellow is offline
Old 10-08-2012, 04:24 PM
scott4.6
scott4.6's Avatar
I would guess to get more HP and TQ.
scott4.6 is offline
Old 10-08-2012, 06:02 PM
sn95_331_GT_ yellow
youre aware that these heads will support 9000+ rpm out of the box...
Old 10-08-2012, 07:13 PM
scott4.6
scott4.6's Avatar
I seen the new trick flow heads, they are 195 cc heads. Shouldnt need to port them for sure. But if he has the 185 cc heads , depending what he is shooting for hp wise i would port them , and a good port match.
scott4.6 is offline
Old 10-09-2012, 10:33 AM
nickpupo00gt
i was told at the dyno they will support 7000 rpm and also i am looking into it to make more power, i have a 301 stroker kit, the heads, tfs track heat intake manifold tfs upper intake and a bunch of fuel system upgrages, also i have a blower that i have not yet gotten on the car
Old 10-09-2012, 10:39 AM
scott4.6
scott4.6's Avatar
In your case i would port them .
scott4.6 is offline
Old 10-09-2012, 02:40 PM
CSteiny
CSteiny's Avatar
I would do 4 valve swap
CSteiny is offline
Old 10-09-2012, 10:13 PM
sn95_331_GT_ yellow
no, your bottom end will support 7000 rpm, theres NHRA ProStock guys running these heads out of the box to 9500+ rpm... trust me save your money and out it elsewhere
Old 10-10-2012, 08:48 AM
Gregg@TFS
Gregg@TFS's Avatar
How much power are you looking to make? If you are looking to make 700-800 at the flywheel on a supercharged combination the 185cc heads will do that all day with out touching them. If you are looking to make more on your stroker combination go with the new 195cc R series head. With the 301 you have enough room to support the bigger 1.90" intake valve and it will make a ton of power. If you have any questions let me know.
Gregg
Gregg@TFS is offline
Quick Reply: Trick Flow Twisted wedge heads
