Tire size
Old 11-12-2012, 08:06 PM
chillindamost
chillindamost's Avatar
Default Tire size
I am looking at getting some new to me tires and rims. I am not sure if the set I found will work though as my car a 2003 gt and the rims and tires are off a 2005.
Anyways the rims are 18x9.5 with a 45 offset, ford svt with 285/40/18 and 255/40/18.
The circumfrence of the tires will put my speedo off by 3mph, but the rim offset and width makes me wonder if they will work??
chillindamost is offline
Old 11-12-2012, 11:46 PM
chillindamost
Well I think I found my answer, yes the rims will fit, but I would need to run spacers front and rear, .75" front , 1" rear, the tires though will be larger effectivly gearing my car up by 4%, huge difference no but would be really noticable off the line. Now to decide if a good deal is such a good deal.
Old 11-13-2012, 09:34 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I would NOT do this
Running a 9.5" wheel is sketchy up front on an SN95 and spacers compound issues of rubbing up front, due to scrub radius. Not only that, but you will likely have to cut the ends off of your existing studs, so they don't protrude out past the spacer and hit the back of the wheel mounting surface. This will force you to never run a wheel designed for your car or replace all the studs on your axles and hubs sometime down the road.
Jazzer
Jazzer The Cat is offline
Old 11-13-2012, 11:59 AM
chillindamost
I opted to not buy the rims and tires, for a few bucks more i will just buy the right ones for my car. Seemed like a good deal until i started looking into it.
2007CalSpec
09-09-2015 05:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
M3hunter
09-05-2015 03:42 PM
Quick Reply: Tire size
