proper procedure to park manual car
I have always turned the car off while in neutral, with clutch pedal up. Then with ignition switch off press clutch pedal down, then set into first gear. Is this the proper way to do it?
Two other scenarios I'm questioning:
1. With car on should I leave clutch pedal down, stick in first, turn car off then release clutch pedal?
2. Car off in neutral, clutch pedal UP. And can I put the stick in first without using the clutch pedal when the car is completely off?
Online I have seen everyone posting mixed opinions on all different ways so I want to see what the guys driving mustangs do.
I shut it off with my foot on the clutch, apply the e brake and let the clutch out leaving it in gear. I don't know that there is a wrong way to park a car. Someone once argued with me about the "strain" on the transmission leaving it engaged but if it can hold back a few hundred ft/lbs of torque I think it will be ok.
You are overthinking things.
I have the clutch in while the car is in gear, pull the parking brake and shut the car off. The parking brake is what holds the car in place with the car being in gear as a back up to keep it from rolling in case the e brake fails for some reason.
I agree you are way over thinking a simple process. But I do think you need put the car in a gear never trust just the PB to hold your car in place. I personally put mine in R and than pull up the PB. Why I don't know that is just what I do
I park with the ebrake only when at my place but leave it in first if I'm on any type of slope. There was a time years ago when I was at a restaurant with a very steep parking lot and forgot to leave my car in gear. After sitting down I heard someone say there was a car in the busy street out in front of the restaurant, I looked out and there was my car sitting there in the middle of a busy 4 lane road. I sprinted out and drove it around back to park, then took the walk of shame back into the restaurant.
Unless you have a highly modified drivetrain (and maybe not even then, IDK), I don't really think it matters in what order you do the steps just so you end up with the engine turned off, the tranny in gear, and the e-brake applied. Personally, I turn the car off while in gear (and holding the clutch), then apply the e-brake and release the clutch about simultaneously.
