What's the best way to go about this?
Okay guys, have a goal of starting the car for the first time this weekend, however I have long tubes, and an automatic. I hear you cant drop the trans without loosening a header, however, can I install the motor with the longtubes on if I angle it enough to where the collectors are below the trans bell housing when setting it in? Can I do motor,trans and headers all as one unit? I have a 4 post lift and a cherry picker. Thought about picking the back of the car up, and trying to install it all as one... Thoughts? trying to do it without dropping the K member....
Good luck man, that's why I have shorties. You might be able to get it all out as one whole piece with a little love. I get mine tuned this Monday so I'm anxious to compare power numbers with our similar setups. Your cams are a tad taller than mine, but mine are open longer. BTW have fun holding the gas pedal when you come to a stop before you can get it tuned. Mine was a PITA to drive at first, it was stalling everywhere.
When I put my motor in last winter with LT and trans attached I managed to get the damn motor wedged in a weird position I eventually got it in but it was a PITA. Had I just dropped the k-member it would have been a million times easier
