Ticking caused failure, please help
Old 01-29-2013, 06:25 PM
Fafhrd
Fafhrd's Avatar
Default Ticking caused failure, please help
I am thoroughly stumped here, and could use some advice.
10 days ago, I got the ticking described elsewhere, and resolved it by changing the timing chain tensionor and arm. It was the passenger side that failed. The ticking returned shortly after, but only at heavy rpm. Better, but I need to fix again. I babied the car for about 4 days, trying to keep the rpm in the quiet zone.
On the way home, I suddenly began running poorly with a huge loss of power. The oil gauge dropped to 0, but all other gauges looked fine. I turned a corner to park, and the car died. I coasted off the road. I tried the key and just got a heavy clunk/click. Towed home, tear it apart again.
Passenger chain was loose and had partially slipped off the arm. I believe I may have been given the wrong side, as I noticed it would have fit better if an aspect was just a bit longer, which wow, it was on the old original one. Anyways, a key test failed to do anything other than the clunk sound. Locked up. I pull the valve cover, looking very close at the springs and whatever I can see of the valves. Nothing looks bent, kinked or anything else. I pulled the plugs thinking maybe a flood of gas, but no pressure was released. I went ahead and took the chain completely off, hoping to free any top end damage from the crank. It still doesn't turn.
Please tell me it's something silly or stupid and not a crank bearing failure or some such. I have never heard anything from them before.
Fafhrd is offline
Old 01-31-2013, 05:47 PM
Fafhrd
Fafhrd's Avatar
Anyone? I'm really stumped on this! 4.6, 2002 GT
Fafhrd is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
GLOCKer
09-28-2015 07:36 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: Ticking caused failure, please help
