Can you test a Coil Pack (COP) with an ohm meter?
Old 03-21-2013, 06:33 PM
tracyballard
tracyballard's Avatar
Default Can you test a Coil Pack (COP) with an ohm meter?
Before I blow a lot of money on new coils to try to cure my misfire on 5 which is no longer giving codes, but still missing, I thought perhaps I should actually see if they are in bad shape first. Can you perform a diagnostic test on the cop with a multimeter? Such as testing the resistance across the primary and secondary circuits? what should the readings be if so?? thanks!
tracyballard is offline
Old 03-22-2013, 10:22 AM
johncrist1988
johncrist1988's Avatar
Yes, you can. And just like that, too. Measure resistance and measure current. Ground out on the chassis.
johncrist1988 is offline
Old 03-22-2013, 07:37 PM
robb15033
robb15033's Avatar
I have Ohm'ed them out on a bad set & got consistent Ohm readings phase to phase all the way around. Tricky for me.
robb15033 is offline
Old 03-22-2013, 08:14 PM
tracyballard
thanks for the answer. Do you happen to know what setting I should use on the ohm meter, and what the reading should be?
Old 03-22-2013, 11:11 PM
johncrist1988
My multimeter auto ranges. When I touch the primary terminals (the ones on the inside) I get a resistance of 0.500 ohms. When I touch the secondary terminals I get 5,520 ohms.
Old 03-23-2013, 11:56 AM
tracyballard
I guess since I'm using a 20 year old multi meter I may be at a disadvantage. but I'll see if I can get readings similar to the ones you've listed. those are about the same as some specs I saw for an older Ford coil pack, so I guess nothing changes much. thanks for the input!!
Old 03-24-2013, 01:18 PM
MagnumRooster
MagnumRooster's Avatar
So how exactly does a person accomplish this, the current readings that is, with everything unhooked to gain access to the COP's? What kind of current is supposed to be flowing thru these things, I know they are supposed to put out somewhere in the kV area for voltage but usually high voltage means low current.
I guess my biggest question is are you supposed to unhook one, crank the motor take the reading then proceed to do the same all the way around the motor?
Another question, how can you know what exact cylinder is misfiring?
I am having issues with bucking on acceleration in lower rpm's that i feel might be related to some emissions type issue. But i would like to rule out COP.
MagnumRooster is offline
Dathan
10-05-2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Florida Regional Chapter
09-30-2015 08:04 PM
GT350 S550 Tech
09-29-2015 03:29 PM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: Can you test a Coil Pack (COP) with an ohm meter?
