what should i do to my 2004 mustang gt
i just gave you 20psi as an example. but it all depends on what supercharger you get. Also depends on what pulley you are running. If you get a good sized blower and run a pulley for 20psi, you will have to get a dyno tune to get your air to fuel ratio on track. that is the big thing right there. the tune. without the correct tune and air to fuel ratio, bad things can happen to your setup. If you go to a reputable shop and they get the tune spot on, the power you would make would be great
if you want 500hp youre going to need forged internals and a BIG blower. stock power your looking at 260 engine horse power. takes a LOT to double your power but with enough money it can be done.
updated list
4.10 gears
Off road X pipe.
Magnaflow Muffelrs or SLP LM
Blower+forged internals
upgraded Throttle body +plenum + MAF
cam swap / port and polished heads
a good dyno tune + a hand held tuner
under drive pully upgrade
brembo brakes/ larger better rotors
Springs and Struts upgraded
LONG TUBE headers
upgraded fuel pump and injectors / adjusted ECU for more pressure.
honestly it might be easier and faster to just buy a 2003 cobra and put a KB Blower on it. They already have forged internals and its DOHC and IRS.
updated list
4.10 gears
Off road X pipe.
LONG TUBE headers
yah your probably right about just buying a cobra but i already have my mustang gts exterior and interior completely finished with bbs rims darkish red paint and sparco racing seats with a cobra body kit on it, so it looks like a cobra just not engine and performance whise. so i kinda want to keep this platform. ive put alot of money already into it and time. so i want to stay with my gt . but the list you gave me should put me around that range of 500 correct!?!
updated list
4.10 gears
Off road X pipe.
LONG TUBE headers
updated list
4.10 gears
Off road X pipe.
LONG TUBE headers
Find a tuner in your area and talk to him BEFORE you build. You can buy crate engines packages from motor builders all ready to drop in your car. There is a thread here some where. brb
look around here, http://www.brenspeed.com/05-08-musta...ne-engine.html
I cant find the thread right now that has a good list of motor builders that offer good packages complete.
