Tutorial: Seat Belt Recoil
what you need
-needle nose pliers
-nut driver or socket and ratchet set with 1/4 inch drive ratchet
-Torx T45 if you want to take off the seat belt
If your seat belt will no longer pull out you can reset it by letting it full recoil and pulling it all the way out, usually you'll find it folded over wrong in the recoil.
remove door's floor panel.
remove foam inset behind rear passenger seat
remove coat hanger clip.
remove plastic inserts on 1/4 panel. 3 on back and one on side under other plastic panel.
remove two small inserts that hold the weather stripping.
pull out and there it is.
-needle nose pliers
GT350 S550 Tech
09-29-2015 03:29 PM
autoedit
09-27-2015 06:37 PM
