persistent power steering leak.
Old 04-18-2013, 05:11 PM
HrtBrker991
HrtBrker991's Avatar
Default persistent power steering leak.
i just bought this 2001 cobra and it had a leak from the high pressure line at the pump. so i replaced the line. still had a leak. so i went and got a new Teflon****O-ring****to put on it, and it STILL leaks around the threads. im at a loss now. is there a special way to put this on so it doesnt leak? is there something im missing? or is there something i can put on the threads to stop it from leaking without screwing up the pump itself ( i heard plumbers tape will get in the pump and tear it up). any help is appreciated.
HrtBrker991 is offline
Old 04-19-2013, 02:30 AM
petrock
petrock's Avatar
The threads in the pump may be damaged or cross-threaded. Also make sure that the old teflon o-ring or any other stuff is in the bore. Good luck...
petrock is offline
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: persistent power steering leak.
