Battery light in dashboard randomly turns on
Old 04-22-2013, 09:59 PM
JJ Glo
JJ Glo's Avatar
Default Battery light in dashboard randomly turns on
What could be the cause of the car's battery light randomly turning on while driving the car? Sometimes it turns on for a couple of minutes, then it turns off.
I don't believe there's anything wrong with the battery because it can hold a charge over several days.
Would a dying alternator do this? Or could it be a problem with the cables?
JJ Glo is offline
Old 04-22-2013, 10:19 PM
mrz2207
mrz2207's Avatar
You should test what your battery voltage is and how much voltage your alternator is putting out.
mrz2207 is offline
Old 04-23-2013, 02:44 AM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Does it come on when the RPM's are higher?
PROMETHEUS PRIME is offline
Old 04-23-2013, 10:03 AM
JJ Glo
JJ Glo's Avatar
Well, it has turned on from just driving it in the city, so the RPM's aren't usually high, 1.5-2.3k maybe.
JJ Glo is offline
Old 04-23-2013, 10:25 AM
QATIM
QATIM's Avatar
I'm interested in an answer to this also. My light has been doing the same thing. I've had it looked at, coded the whole nine. It's throwing no codes. At my wits end.
QATIM is offline
Old 04-23-2013, 10:30 AM
PROMETHEUS PRIME
If the brushes on the alternator are weak at higher RPM's they separate and loose charging. That are the regulator is goin out. Either way it most likely is the alternator.
Old 04-23-2013, 04:47 PM
DRAGUL
DRAGUL's Avatar
I have had this happen in the past on a few of my work trucks. Light would randomly go on and off until the alternator crapped out, then it would stay on all the time.
DRAGUL is offline
Old 04-26-2013, 01:10 PM
Subbz
Subbz's Avatar
Same thing has been happening to me. I got the battery and the alternator checked out by my mechanic and they were both fine. My voltage never drops so I'm not quite sure what causes it. Anyone have a definitive answer to this?
Subbz is offline
Old 04-26-2013, 03:25 PM
ZeroTX
ZeroTX's Avatar
The light comes directly out of the alternator. I thought it was fine, because it was making like 13 volts almost, but evidently it needs to make a lot more than that. I bought a brand new generic alternator (new, not rebuilt) off eBay for like 80 bucks and it fixed it.
ZeroTX is offline
Old 04-26-2013, 04:10 PM
lizzyfan
Underboss
lizzyfan's Avatar
Yep! Without question!!
lizzyfan is offline
Quick Reply: Battery light in dashboard randomly turns on
