Oil blowing out RADIATOR. No oil in block, no coolant in oil
Old 05-04-2013, 01:29 PM
Fastblackstang
Fastblackstang's Avatar
Yes lets hope but I don't think that's your problem. That old gasket does not look destroyed but I am looking at a picture I don't have it in my hand lol. Be sure to change oil plus filter (which I'm sure you gonna do because u have the oil cooler off) and coolant (which I know u are trying to flush) just to be safe you never know if a little bit of coolant made it into the oil. I know u said its bone dry on the dip stick but I"m sure there is still oil in the bottom of the pan because the dip stick does not go all the way to the bottom of the oil pan. Well good luck keep me posted.
Fastblackstang is offline
Old 05-04-2013, 04:24 PM
Doublevision
Doublevision's Avatar
Could i run defreaser through the coolant system just once? The radiator has been flushed many times and still it is sticking to everything inside. I can see the oil stuck to the inside of everything. Its not really flushing out.
I was thinking some purple power then flush a few more times to clean it out.
Doublevision is offline
Old 05-04-2013, 04:43 PM
Fastblackstang
I assume u mean degreaser lol. Honestly I have never done that or heard of anyone doing that, I don't know what that may due to seals I would read the product over good I'm sure u could dilute that with water, I would put it all together run maybe a diluted batch of that in place of coolant and run engine just tell it gets warm/hot or maybe tell thermostat opens or you maybe can remove the thermostat during your process to get your flush to move threw block and heads a little better do not run it forever then flush it by removing the lower radiator hose and let it flow before it cools down and sticks again when removing hose being careful not to get burnt. Oil is like grease in a pan when its cold it tends to stick but when u get it warm it thins out and moves. I know what your saying u want all that crap out. I know there is coolant flushes out there u can by at a local parts store just don't know how well they will work against oil.
Old 05-04-2013, 05:46 PM
Doublevision
Well i have prestone super flush i am running through it now. I was just preparing for when it doesnt work. Its about warmed up and finishing as i type.
Old 05-05-2013, 05:19 AM
Fastblackstang
How did you make out? Did that super flush get rid of that oil sledge in the coolant passages?
Old 05-05-2013, 11:34 AM
Doublevision
Lol I assume you mean sludge. It made it milky and therefore helped but im still flushing.
Old 05-05-2013, 12:56 PM
Doublevision
This is what i get with the prestone super flush and super clean.
Old 05-05-2013, 02:11 PM
Fastblackstang
Looks yummy lol, so is it helping for the most part to get the oil out of the cooling system? Are you noticing if oil is pumping into coolant as your running it again? Also I was reading back and you said that u checked to see if there was coolant in the heads what did u just look through oil cap or did u actually pull the valve cover? Also did you drain what was left of the oil in the pan to see if u had coolant in it since u said the dip stick showed nothing? Also you mentioned intake gasket, in our engines the only thing that goes through the intake gasket is coolant, there is a crossover passage in the front where thermostat is and nipple in the back where it comes back from the heater core in dash so there is really no place for contamination there. The only real places are in the heads/head gasket, if there was a crack in the block which I highly doubt these are cast iron blocks or the oil cooler which u replaced the gasket on or a crack in oil cooler. So if this don't solve your problem I'm gonna lean pretty heavy on the head gasket being bad. If in fact u need to replace your head gasket I don't know how good your mechanical skills are but its really not as bad as people make it out to be. As long as you have a decent memory and have pretty much a socket set with metric sockets lol you should be ok doing it. The only thing that you would need to get if you didn't have would be a torque wrench, a crank pulley puller to get the front cover off and fuel line disconnects to get fuel lines un hooked from fuel rail. But again let me know, I have taken an interest to solving your problem, it keeps me involved and thinking. I just had hand surgery and cant return to work for a month so it sucks but talking about fixing things takes my mind off not working cause I feel like I'm helping another mechanic and fellow mustang friend lol. Well good luck keep me up to date!
Old 05-05-2013, 11:51 PM
Doublevision
I think I have it flushed enough to be good to drive. It's NEARLY cleaned out after 29 flushes over 3 days. (AYE!) The Oil Adapter plate gasket seems to have been the issue. I've driven it 175 miles in the past 2 days and not lost a drop of oil. Given that the previous state was zero oil left in the pan and overflowing radiator full of oil I have to conclude it worked. Will monitor for the next week, see how it goes.
Old 05-06-2013, 12:00 AM
Fastblackstang
I am glad you got it going, good lets hope its just that. Yea keep a good eye on it, I don't know how often you check your fluids but it may be a slower process it depends how wide the crack in the gasket was or is. But cool enjoy!
Quick Reply: Oil blowing out RADIATOR. No oil in block, no coolant in oil
