Rear tire wobble
Old 06-09-2013, 01:25 PM
Kooktaman
Kooktaman's Avatar
Question Rear tire wobble
When driving my car on the highway at around 60-70 mph my rear tires seem to wobble or oscillate and I can't seem to figure out what the problem is. i have had the tires balanced and i am almost positive that the rims are not bent. i just got new tires also and the problem still persists. The rear tires are 265/35/18. Any input or possible solutions would be greatly appreciated thanks
Kooktaman is offline
Old 06-09-2013, 01:27 PM
Carcrazycorey1
Carcrazycorey1's Avatar
this might sound silly, but have to checked to make sure the lug nuts are tightened properly?
Carcrazycorey1 is offline
Old 06-09-2013, 01:47 PM
Kooktaman
Kooktaman's Avatar
yeah I just got the new tires put on this morning and I checked the lug nuts before leaving the shop.
Old 06-09-2013, 07:58 PM
Darkhorse04GT
Darkhorse04GT's Avatar
If it only vibrates/wobbles at a certain speed, you're describing is a balance problem.
How do you know they're wobbling? Do you get steering input or do you feel it in your seat/feet?
Darkhorse04GT is offline
Old 06-10-2013, 07:36 AM
Helo-tech
Helo-tech's Avatar
if the tire shop was able to balance them, the rims cannot be bent. I'd be willing to bet you have a bent axle if they wobble all the time.
Helo-tech is offline
Old 06-11-2013, 11:39 AM
Kooktaman
Kooktaman's Avatar
I can feel it in my seat and i can see my rear view mirror vibrating/moving.
I"ll have to check that out Helo-tech thanks.
Old 06-11-2013, 01:40 PM
uberstang1
Chupacabra
uberstang1's Avatar
If u jack up the rear is there any wobble or play in the wheel? if so could be an axle or carrier bearing. Also did u hit anything recently if so axle end could be bent.
uberstang1 is offline
Old 06-11-2013, 07:07 PM
FlamingoGT
FlamingoGT's Avatar
What kind of balance did they do?
Did you check the runout on the wheel, both while off the car and while mounted?
FlamingoGT is offline
Old 06-11-2013, 09:35 PM
DJINN n TONIC
DJINN n TONIC's Avatar
While you have it Jacked, Look closely at the "U-Joints". Just because they dont make noise, doesnt mean they are good, and can easily vibrate within a narrow load/ speed range, just like a tire.
DJINN n TONIC is offline
Old 06-23-2013, 11:32 AM
Kooktaman
Kooktaman's Avatar
I jacked up my car and there was no play or wobble in the wheels and i checked the axles even though i haven't hit or ran into anything recently and they seemed fine.
As far as balancing they did a dynamic balance where they put it on the machine and it spins the tire. But no i did not check the runout and to be completely honest i have no idea how to.
I also looked at the u joints and they seemed good there was no play in the driveshaft or anything.
Quick Reply: Rear tire wobble
