comp cams stage 1 with supercharger?
I put on stage 1 comp cams on my car and im wondering if I have y I change back to stock in order to supercharge it. I never planned on supercharging it but I decided I'm going to but I want to keep my N/A stage 1 comp cams. Thanks
Don't worry, those cams and a little boost will max out your cast rotating assembly. There are a few guys around here running or have run comp's 270 cams with great power. Comps 262 has a duration @ .050 of 224/232, lobe separation of 114 degrees and 110 intake centerline. Hitech stage 2 blower cams 234/230 duration, 112 lobe separation. As you see, your cams are less aggressive than a cam for a blower engine. Most times the blower cams are less aggressive. you will be fine with your cams
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
