315s on SN197 Wheels on SN95?
Personally, I'd be more concerned about how the S197 offset on the FRONT wheels affects the steering/suspension geometry.
S197 on the fronts just tuck in due to the wrong offset. They don't have a negative impact on the ability of the dampers to control rebound at all. Steering might rub at full lock, depending on tire size.
Rears/tires in question will touch the inner edge and won't spin without rubbing.
Rears are the greater issue with this set up.
I've had SN197 wheels on the front and they only rubbed when I did I full turn like a U turn. Might've been because the tire profile was 55 lol. But the rear is the only part that worries me, since they are fat tires and might rub against the quad shock or fender well.
And it was wrong - which is why I posted my comment. On a daily driven street car, there will be no noticable change in steering or movement of the front suspension geometry due to the change in offset.
Sonic, you providing info if the wheel has extreme positive wheel offset. Which unless the op has a liking for wheel/tires sticking out past the fender, he wont come close to positive offset. even with one inch spacers, he still have negative wheel offset and close to the sn95 offset provided wheels from AM.
specs for s197 (05 and up)
Manufacturer: AmericanMuscle Wheels Style: Bullitt
Size: 17x9 Finish: Chrome
Placement: Front or Rear
Centercap Size: Large (2-1/2")
Back Spacing: 5.94" (151mm)
Offset: +30mm (1.18")
Bolt Pattern: 5x4.5" (5x114.3mm)
Weight: 23.7 lbs
Material: Aluminum Lip Size : 2.5"
Best Tire : 255/50-17
Year/Model: 2005-2014 V6, 2005-2010 GT, Excluding GT500
sn95 (94-04)
Placement: Front or Rear Centercap
Weight: 23.7 lbs
Material: Aluminum
Lip Size : 2.5"
Best Tire : 1994 - 1998: 255/40-17 1999 - 2004: 275/40-17
Year/Model: 1994-2004 All
Surprising, the sn95's and s197's share the same offset on the 17x9 wheels. But the lip size is different, im assuming its for brake caliper clearance. Op, I appolagize, the front wheels will fit the same BUT the rears will need a spacer so the tires wont rub the wheel wells.
Weight: 23.7 lbs
sn95 (94-04)
Weight: 23.7 lbs
Material: Aluminum
Lip Size : 2.5"
Second, just because an illustration shows two extremes for clarity doesn't invalidate the effect of smaller changes in offset. The change may be smaller and its effects on steering, handling and suspension smaller, but the effects are still their.
It appears AM's SN197 17" Bullitts are identical to their SN95 Bullitts with respect to offset. Note that Ford Racing S19717" X 8" Bullitts have a 45mm offset. AM's S197 17"X 8" Bullitts are 30mm. This tells me AM isn't bothering to build and sell an S197 17" X 8" wheel with the correct offset.
