315s on SN197 Wheels on SN95?
I came across some Bullitt Wheels from an SN197 that I can get really cheap. The tires and wheels are Brand New and are from American Muscle. The Rear Tires are 315s on a 17" Rim I believe. My question is will they fit on a stock 99-04 mustang GT without rubbing? I know the offset is a little bit different and don't know if those big tires will fit fine, I've read on forums that some people have no issues while others do. I did have SN197 Bullitts on my old V6 and they only rubbed when I did very sharp turns or U-Turns but that might of been because of the tire hight was 55.
Will the 315s on a Deep Dish Bullitt from a SN197 fit a 99-04 fine?
Will I need Wheel spacers?
Thanks,
Thanks,
You may need 1" spacers
s197 specs
Manufacturer: AmericanMuscle Wheels Style: Bullitt
Size: 17x10 Finish: Chrome
Placement: Rear Only Centercap Size: Large (2-1/2")
Back Spacing: 7.27" (184.7mm) Offset: +45mm (1.77")
Bolt Pattern: 5x4.5" (5x114.3mm) Weight: 25.1 lbs
Material: Aluminum Lip Size :
Best Tire : 295/45-17 Year/Model: 2005+ V6, GT, Excludes 2013-2014 GT500 & 2011+ GT
sn95 specs
Size: 17x10.5 Finish: Chrome
Back Spacing: 6.8" (174mm) Offset: +28mm (1.10")
Bolt Pattern: 5x4.5" (5x114.3mm) Weight: 25.9 lbs
Material: Aluminum Lip Size : 3"
Best Tire : 1994 - 1998: 315/35-17 1999 - 2004: 315/35-17 Year/Model: 94-04 V6, GT, Bullitt, Mach 1, and 94-98 Cobra
s197 specs
sn95 specs
Thanks,
Thanks,
Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
x2. Def going to rub without the spacer in the rear. What size is on the front? They might rub as well.
Why not just wait and buy the correct offset wheels for the SN95 instead of the S197?
Lilroush: I would but I can probably get the 4 Brand New tires and wheels with 0 miles for around $400. And I need new tires ASAP and figured it would almost cost the same to buy new tires.
SXGT: that's what I mean by getting mixed opinions about it rubbing. I guess I'll just put them on before actually buying them and If they do rub ill just have to get a wheel spacer or pass up on them
