Camber/caster plates
Old 07-15-2013, 09:27 PM
mustangfan17
mustangfan17's Avatar
Default Camber/caster plates
If you're lowering a mustang with lowering springs will you need camber/caster plates. What exactly do they do?
mustangfan17 is offline
Old 07-15-2013, 09:34 PM
Nawwz
Nawwz's Avatar
What springs are you using? Anytime you lower a car past 1.5", you'll need caster/camber plates to correct the alignment.
Check out Jazzer's detailed suspension guide: https://mustangforums.com/forum/susp...ion-guide.html
Nawwz is offline
Old 07-16-2013, 10:43 AM
mustangfan17
So if I get the caster/camber plates then I won't need an alignment
Old 07-16-2013, 02:51 PM
supersnake67
supersnake67's Avatar
Yes you will still need an alignment. The plates allow allow more front to back and side to side movement of the front strut. That you can't get with the factory setup. Allowing you more freedom to adjust caster and camber.
supersnake67 is offline
Old 07-16-2013, 02:52 PM
supersnake67
Sorry 1 too many allows..... lol
Old 07-16-2013, 03:14 PM
Nawwz
Nawwz's Avatar
You can edit your posts, supersnake67.
Mustangfan17, the C/C plates allow for modification in your camber (angle of the tire leaning inwards or outwards) and the caster (angle of the tire while steering), as supersnake67 said. It does NOT eliminate the need for aligning the tires. From my understanding, optimal alignment calls for the tire surface to remain flat and at a straight angle to allow for more grip and better steering response.
Nawwz is offline
Old 07-16-2013, 07:08 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
CC-plates give you a greater range of adjustment than the stock strut mounts do. They are recommended, because in addition to giving you more adjustability they also improve on the strut mounting itself by getting rid of the soft rubber factory bushings. But I wouldn't say they are REQUIRED for lowered cars. Just strongly recommended.
Here's what I recommend:
http://www.uprproducts.com/mustang-b...plates-94.html
UPRSharad is offline
Old 07-17-2013, 08:49 AM
mustangfan17
Ok thanks guys this helped me out a lot and now I have a better understanding of cc plates
Old 07-17-2013, 05:22 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Happy to help!
Old 07-17-2013, 07:57 PM
luke1333
luke1333's Avatar
these guys are right added movement for the strut allowing for better alignment! my alignment guy loves me after i put 4 bolt mm cc plates on it. you have tons of movement and can get the alignment spot on! here is what i would go with the 4th hole adds a good bit of movement
http://www.americanmuscle.com/maximu...tes-94-04.html
luke1333 is offline
Quick Reply: Camber/caster plates
