Odometer (Repair #1 of 3) question - not working
Old 08-28-2013, 09:31 AM
rocket22
rocket22's Avatar
Default Odometer (Repair #1 of 3) question - not working
Car: 1997 Cobra Convert. 115K (at least last known)
Owned for 1 year, no history (it was a trade for a 94 vette that had critical issues)
Additional Info: I know the instrument panel was removed as MAL light was removed
Speedo. works fine, odometer and trip do not.
My diagnosis: (based on previous mechanical speedos.) replacement is the fix.
Any other ideas?
rocket22 is offline
Old 09-03-2013, 09:26 AM
rocket22
rocket22's Avatar
Default I will answer my own thread
Order the two gears to fix the Odometer - I ordered off of Ebay for 17.00 This is a common failure on the Mustang.
rocket22 is offline
Old 10-27-2014, 05:31 PM
Pappy5591
Pappy5591's Avatar
My local garage tells me i have to buy and entire new gauge setup for the same problem.
Pappy5591 is offline
Old 10-28-2014, 12:13 AM
ESABATM
ESABATM's Avatar
Just get the gears. I had to do the same on my 95 Tbird when I owned it.
ESABATM is offline
Old 10-28-2014, 08:09 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
your garage is a bunch of dolts, there are 2 plastic gears and one usually breaks a tooth or two off, everything works, but the gear no longer meshes with the other one. Pretty easy fix
Here is when i did it to my 98
the write up
http://www.latemodelrestoration.com/...FeRj7AoduzIA_g
the pieces you need
http://www.latemodelrestoration.com/...epair-Gear-Kit
WhiteFoxGT is offline
Old 10-28-2014, 05:39 PM
uberstang1
Chupacabra
uberstang1's Avatar
+1 you dont need a whole cluster
uberstang1 is offline
Old 10-30-2014, 07:23 AM
Pappy5591
Pappy5591's Avatar
Default Thanks!
Appreciate the feedback, guys!
Old 10-30-2014, 08:15 AM
Pappy5591
Pappy5591's Avatar
Default Ordered!
Just ordered the replacement gears, and watched the how-to video. Believe I may try this repair on my own!
Old 10-30-2014, 08:27 AM
Pappy5591
Pappy5591's Avatar
Default Now...
About the poor lighting for the instrument cluster...
Old 10-30-2014, 03:19 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
replace the bulbs while you have it apart........
Amazon.com: 28-smd White SUPER BRIGHT LED Bulb 194 168 2825 By Zone Tech: Automotive Amazon.com: 28-smd White SUPER BRIGHT LED Bulb 194 168 2825 By Zone Tech: Automotive
Quick Reply: Odometer (Repair #1 of 3) question - not working
