Adding wheel spacer to the rear tires?
Old 09-24-2013, 02:07 PM
Alfonso97GT
Alfonso97GT's Avatar
Smile Adding wheel spacer to the rear tires?
Hey i was thinking of adding a 1 or 1 1/2 inch wheel spacers to the rear wheels of my 97 gt, it currently has the stock wheel and i just want to fill in the wheel well more, any thought or suggestions?
Alfonso97GT is offline
Old 09-24-2013, 02:08 PM
Alfonso97GT
Stock gt wheels.
Old 09-24-2013, 02:19 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Rather than go with spacers which will throw off the 'balance' of suspension, just get wider tires and/or rims.
Derf00 is offline
Old 09-24-2013, 05:30 PM
Sonic Mustang
Banned
Sonic Mustang's Avatar
Adding spacers or wider wheels to increase the rear track isn't going to throw off the "balance" of a solid rear axle suspension. The spacers maight not be balanced, but that's another issue.
However, I would avoid spacers simply because I do not want extra bolts and parts in my drive line. More failure points and the possibility of of imprecise machining leading to balance and run out problems - no thanks.
Sonic Mustang is offline
Old 09-24-2013, 06:53 PM
WJL
WJL's Avatar
I have a 98 and i want to do the same thing i would like to put 1 1/2" but would settle for 1". I looked on American Muscle and it said you cant use them with stock wheels. You can get then with hubcentric centers which may help with any balancing issues. Much cheaper than buying new rims & tires (two kids in college) I do like to push the pedal but i'm not at the strip every weekend. So for the cost i say go for it
WJL is offline
Old 09-25-2013, 12:55 AM
Alfonso97GT
I would love to get wider wheels and tires but for now cash is a little tight.
Old 09-25-2013, 12:57 AM
Alfonso97GT
I was also thinking of going with Hubcentric spacers to minimize possibility of throwing the wheel spin off center balance.
Old 09-25-2013, 01:19 PM
1slow67
ROTM Moderator
1slow67's Avatar
I ran I believe 1.25" spacers on my gt just fine. Mine were hubcentric.
1slow67 is offline
Old 09-25-2013, 03:48 PM
antwaan
antwaan's Avatar
I've been using wheel spacers for 5 years or so on my GT rear wheels. The look is so much better. I think they are 1.25". They worked fine with stock wheels when I used to run them when it was my dd. Get them bitches tight though. Tighten them, drive 100 miles then take the wheels off and tighten them some more.
antwaan is offline
Old 09-25-2013, 07:39 PM
stangcoupe1970
stangcoupe1970's Avatar
I bought my spacers back when I had my ranger 5 years ago, they went on it, the explorer I had after that and now they've been on my 98 gt for 3 and a half years.
I only have the rear spaced out on all 3 vehicles and stepping the back wheels out made them feel more stable while turning.
stangcoupe1970 is offline
Quick Reply: Adding wheel spacer to the rear tires?
