Smoke from exhaust???
Old 10-18-2013, 08:52 PM
thatdude305
thatdude305's Avatar
Default Smoke from exhaust???
I noticed a little bit of grey smoke coming out of my exhaust pipes when the car accelerates. I also noticed it when I sit at a light for a while or im in traffic, but its usually a little bit more. enough to see while im driving????
thatdude305 is offline
Old 10-23-2013, 05:53 PM
gjscott
gjscott's Avatar
Grey smoke is typically burning oil. If you get it when accelerating it you may have worn piston rings. This is normal with high mileage.
How many miles are on your car ?
Are you losing oil ?
gjscott is offline
Old 10-24-2013, 05:36 AM
uberstang1
Chupacabra
uberstang1's Avatar
When I still had a two valve in my car I had the same simptoms, ended up being valve seals.
uberstang1 is offline
Old 10-24-2013, 06:29 PM
thatdude305
I have just over 96,000 miles and I lose a little oil I think, but when I bring it to get serviced they never say anything about it being low.
Old 10-24-2013, 06:31 PM
thatdude305
Also about how much should it cost to replace valve seals???
Old 10-25-2013, 07:07 AM
uberstang1
Chupacabra
uberstang1's Avatar
Not sure on price, but changing valve seals can take some time, and time=$$$
Old 10-25-2013, 03:59 PM
96t-bird
96t-bird's Avatar
+1 on the valve seals. as stated will take some time and time= $.
96t-bird is offline
Old 10-26-2013, 03:18 PM
Aaron Bridges
Aaron Bridges's Avatar
Valve Seals definatly mine went out on my 96 cost me about a grand but I also did a head swap at the same time. IF your wanting to put cams in I would do it at the same time youll be right there.
Aaron Bridges is offline
Dokilar
15
10-16-2015 08:13 PM
09-30-2015 12:39 PM
RCS02v6
09-29-2015 01:46 PM
MacSerio
09-27-2015 01:05 PM
09-24-2015 09:18 PM
Quick Reply: Smoke from exhaust???
