timing cover oil leak w/pics
I was under my car today searching around for a creek noise when steering when I noticed that I had oil on my oil filter. so I searched more and found what it looked like the timing chain cover is leaking oil. I can't tell if its leaking from the timing cover or a head gasket. Maybe one of you guys could help me. I have roughly around 170k on the car, not really sure due to the speedo being way off, and the motor is bone stock besides cai.
and is there a replacement gasket? I have searched and can't find anything.
How hard is it to do this job?
thanks
thanks
Doing the front cover is a job but it isn't hard technically just labor intensive. Gotta remove both valve covers (so replace those gaskets while you're there) and everything on the front of the engine. But all you really need is an 8,10, and 13mm.
Okay, done some more research and it seems pretty straight foward I hope. Now my only concern is how to get the harmonic balancer off. I have never messed with one of these, and is there a certain tool or special way to get it back on?
and can someone give me the torque specs for valve covers, timing covers, any pulleys i need to take off and harmonic balancer
Make sure you get the right valve cover gaskets, Ford made about a quarter million different designs in the decade or so of the 2v. You should replace the valve covers as mentioned, the front cover gaskets, and the front crankshaft seal to be all inclusive.
Don't forget a dab of grey RTV sealant in the in the corners of the oil pan and back on top where the cover meets the block when you re-install the valve covers. You will need a tool to get the balancer off. To get it back on you will either need a longer bolt, a thinner washer, or the tool.
Okay. The timing cover gasket comes in 3 pieces and a seal. I'm guessing that's the seal you're talking about. So do I put rtv where the gaskets meet on the timing cover since its a 3 piece?
None of those seals actually meet anywhere, one is for the right side, one the left, and one for the middle. There is probably some sealant in the places you need to replace it in already.
But like I said, corners on the oil pan and on top where the cover meets the block when re-installing the valve covers.
