Idler pulley broke off timing cover
Old 12-26-2013, 03:19 PM
nathansmith50
nathansmith50's Avatar
Also...those painted valve covers look AWESOME. I am now really lamenting my laziness in cleaning and painting mine when I did my headswap.
nathansmith50 is offline
Old 12-27-2013, 06:48 AM
tangystang
tangystang's Avatar
thanks man. and I finally got to drive my car last night after about a week of it being broke down in the yard. but the idler pulley seems to be holding up even under hard acceleration. but thanks man, yeah i had to replace the timing cover gasket and figured i would paint them while they were off. looks a million times better under there.
tangystang is offline
Old 08-14-2016, 01:28 PM
robbie shirkowski
robbie shirkowski's Avatar
Default 2002 idler pulley
If I bypass the idler pulley do I have to hang the tension pulley. Will the grooves in the pulley line up the the new route the belt takes?
robbie shirkowski is offline
Old 08-23-2016, 06:13 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
what
how about go try it and let us know
if you want to try and bypass the pulley like in the original post....a shorter belt might get you home, but it will squeak and slip on higher RPMs
WhiteFoxGT is offline
Old 08-27-2016, 12:34 PM
Camster
Camster's Avatar
No reason that remaining pulleys would not be in alignment.That said,Ford didn't put in parts that were not required.Without the tension pulley,how do you propose to install a belt AND have it properly tensioned? There is no adjustability for the alt,water pump,etc.
Camster is offline
Old 12-09-2021, 09:36 PM
jonathan2000gt
jonathan2000gt's Avatar
Default helppppppppp!!!!
Originally Posted by tangystang
Well I think I have fixed it. I used a longer and bolt, and was able to torque it down to 20ft lbs. I couldn't find torque specs no where so I just did 20. But I won't know until I fix my power steering leak. The pump is off the car.
i had the same exact issue looks identical can u please tell me if u used washer, how its looking possible length of the bolt pleaseee i finally got my engine swap done and really dont wanna have to do a timing cover, hows it lasting?
jonathan2000gt is offline
Old 02-01-2022, 01:35 AM
JoeyM
JoeyM's Avatar
Mine broke up the same way doing the same thing but the belt still fits on it even without the idler and I've run it for over a month and so far I have seen no difference in results but I but I could be wrong
JoeyM is offline
Old 02-01-2022, 01:46 AM
JoeyM
JoeyM's Avatar
Originally Posted by ESABATM
^^^^THIS^^^^
Just like Mine broke off I tried JBL welding to put it back on and at 1st it worked for a while until it ripped through my serpentine belt had to get another one and then pulley lbroke off again and I tried to do a torque do a torture lock on it but ended up messing up the new surfing belt too so I just have it off because it is a pain in the neck too replace the timing cover.
JoeyM is offline
Old 02-01-2022, 01:52 AM
JoeyM
JoeyM's Avatar
Yeah I ended up buying 2 new belts from trying to put the bolt Back on Quit JBL Weld and Thread locker but somehow it kept going through the Serpentine belts so I have it off and no the tensioner does not touch anything else runs great I've been running it like that since then
JoeyM is offline
Old 02-01-2022, 10:58 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Who needs idlers or tensioners anyway that stuff is for the birds
Quick Reply: Idler pulley broke off timing cover
