P0174 lean Condition
Old 01-11-2014, 08:08 AM
Aaron Bridges
Aaron Bridges's Avatar
Post P0174 lean Condition
So I have been fighting this lean condition for about 3 months now Ive replaced just about everything that could cause the condition in the first place. Fuel Filter, Fuel Pump, Intake manifold and all gaskets, Injector O rings, Check FPR and FR's all good Fuel Pressure is sitting pretty at about 39LB's only I haven't replaced is Injectors Wiring Harness and PCM. the problem is intermittent when I had it Dyno tuned it was kicking on and off running good then bad and so on and so forth. He said it screams electrical. I got a steal on a set of Harnesses Injector harness and O2 Harness, Some of My pigtails have broken over time anyways... How hard is the install of these harnesses? would it be worth 200Bucks to have someone else do it? or can I throw it in there in a couple of hours? Im going to Install the new Inj myself I'm just tired of ****ing with this thing. Im hoping the harness is the problem. also Just in case it isn't I got a PCM from a 97 would there be any problem aside from just having dealer install and reflash?
Aaron Bridges is offline
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
winner99
10-01-2015 01:06 PM
mdg
10-01-2015 07:04 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: P0174 lean Condition
