1997 Cobra - Upper Intake Manifold Gaskets - what is this piece?
Old 05-19-2014, 07:15 AM
rocket22
rocket22's Avatar
Default 1997 Cobra - Upper Intake Manifold Gaskets - what is this piece?
I finally had some time to get the intake manifold off to replace upper/lower manifold gaskets which will hopefully allow me to pass emissions (Stock engine). When I removed the driver side fuel rail there was a small 1 x 1 piece of black thin foam pad. Does anyone know where this would be from? There is no way it was under with the gaskets, and I am guessing it is a pad to prevent some wire from chaffing. I don't see this anywhere in the 1997 Full Service Manual. I am going to start reassembly today once the gaskets arrive.
Note: This engine is a PITA for this repair. Easily twice as complicated as a pushrod engine. The Coolant crossover tube was a pain along with the front mounting bracket. I documented the removal, now just need to put it all back together, cross my fingers.
rocket22 is offline
Old 05-19-2014, 03:05 PM
DeathRattle
DeathRattle's Avatar
Post a pic.
DeathRattle is offline
Old 05-20-2014, 09:21 AM
rocket22
rocket22's Avatar
Default I will post in the next few days - deathrattle
Deathrattle - is that taken from the noise the OHC chain noise in Ford Engines? Specifically the 4.0?
rocket22 is offline
11-10-2015 11:39 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
09-08-2015 06:25 PM
Quick Reply: 1997 Cobra - Upper Intake Manifold Gaskets - what is this piece?
