Going from 21 lb to 24 lb injectors
Old 08-26-2014, 08:47 PM
Evan02
Evan02's Avatar
Default Going from 21 lb to 24 lb injectors
Would that negatively affect my gas mileage?
Evan02 is offline
Old 08-27-2014, 12:37 PM
CalBoy101
CalBoy101's Avatar
If you don't get a tune it will definitely hurt your mileage and performance.
With a tune the gas mileage will be the same under light to medium throttle.
Your performance will only improve if the engine really needed the bigger injectors, if you are making under 260 or so rwhp then the 21's are good enough.
Datalogging your injector duty cycle at WOT and max RPM tells you if you need bigger injectors, if the current injectors are at 80% or less then you don't need new ones.
CalBoy101 is offline
Old 08-27-2014, 08:05 PM
Soldier GT
Soldier GT's Avatar
What mods do you have?
Soldier GT is offline
Old 08-28-2014, 03:20 AM
Evan02
Evan02's Avatar
Nothing much really, just a couple of bolt ons. I don't plan on installing the injectors until I get a larger plenum and throttle body.
The only reason why I got the 24lb is because I got a really good deal on them.
Evan02 is offline
Old 08-28-2014, 01:21 PM
uberstang1
Chupacabra
uberstang1's Avatar
Honestly dude there no reason to even run them, there not needed with those mods and there not gonna add anything, its just a waste even with the throttle body still dont need em.
uberstang1 is offline
Old 08-29-2014, 06:28 AM
Evan02
Evan02's Avatar
Thanks, I'll probably just save myself a head ache then
Evan02 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: Going from 21 lb to 24 lb injectors
