calipers locking up
Old 03-30-2015, 11:39 PM
floyd941
floyd941's Avatar
Default calipers locking up
I replaced my master cylinder because it was leaking...then after that my calipers will keep loxkin up and i git to bleed the mc in order to move it again
floyd941 is offline
Old 03-31-2015, 06:40 AM
99GTvert
is my username.
99GTvert's Avatar
Slider pins greased? Pads installed correctly? Do all calipers lock up or just one?
99GTvert is offline
Old 03-31-2015, 08:01 AM
jwog666
jwog666's Avatar
its possible that brake system was contaminated with oil? this will cause seals to swell and calipers and master to stick. just a thought
jwog666 is offline
Old 03-31-2015, 09:58 AM
swarthyfellow
swarthyfellow's Avatar
Are you bleeding both the master cylinder bleeders? Use a tube turned up on them to when bleeding to keep air out, works well. I believe you should close the front one first if i remember correctly.
swarthyfellow is offline
Old 03-31-2015, 10:21 PM
floyd941
floyd941's Avatar
Yes pads installed correct and I greased sliders...only the rear calipers lock up
floyd941 is offline
Old 03-31-2015, 10:27 PM
floyd941
floyd941's Avatar
To be honest with you sir...I don't no what the proper way is to bleed the system...first hydra boost vechile I've owned....I start and do the back right rear then back left...then front right then left....I don't no how to bleed mc...I took it to ford and they told me the abs modular is out...they told me I would have to replace that before they could even tell me what's wrong ?
floyd941 is offline
Old 03-31-2015, 11:37 PM
jwog666
jwog666's Avatar
vacuum boost or hydro boost makes no difference in how you bleed em FYI
jwog666 is offline
Old 04-01-2015, 06:56 AM
99GTvert
is my username.
99GTvert's Avatar
Parking brake working?
99GTvert is offline
Old 04-01-2015, 07:02 AM
swarthyfellow
It doesn't seem to matter what order you bleed the calipers up front, in the back i do the driver side first due to it having the longer length line after the rear slitter. However, you do need to bleed the MC first. Other wise you are pumping air back into the lines.
Jwog is right the hydro-boost unit no bleeding it lets are out in the PS tank.
I have never heard of a bad ABS unit doing this, but I don't know. Sounds like a ford scam. Anyone else heard of this? I don't even have power to my abs and it been fine for 4 years.
Old 04-08-2015, 08:07 PM
floyd941
floyd941's Avatar
Yes ir they work
floyd941 is offline
BOB ROME
07-26-2023 01:54 PM
guitarman376
09-30-2015 05:54 PM
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
Quick Reply: calipers locking up
