700hp 4.75l am i on the right track
Old 08-18-2015, 10:37 PM
2003 4.75l
2003 4.75l's Avatar
Default 700hp 4.75l am i on the right track
I recently bought a short blocks from mmr rated for 750 hp now trying to figure out the rest as on Wichita heads and camshaft to go with it get the 700 I'm looking for out of my 2v going to add boost obviously any help would be appreciated thanks. Was thanking the twisted wedge 44cc cnc but not sure on cam size
2003 4.75l is offline
Old 08-19-2015, 07:19 PM
hawks05
hawks05's Avatar
Here is what I will tell you. I have a built 4.6L short block. I have Trickflow heads 38cc, CMS Stage 2.5 N/A Cams, Trickflow Intake Manifold, Professional Products 75mm TB, MAC Long Tubes, Offroad X-Pipe, Amercian Thunder Cat Back. Circle D Stage 3 (multi-disk) 3500-3700 TC. It is putting down about 305 to the tires with a horribly done dyno tune. I need to put in bigger injectors and I'm going to swap in 3.75 gears.
So there is a starting point on where the numbers are.
I would go with Trickflow Heads.
hawks05 is offline
Old 08-19-2015, 08:06 PM
Soldier GT
Soldier GT's Avatar
Trickflow heads are most def a good start. What type of FI are you going with (Vortech, KB, Procharger etc.,)? You'll most def spend a preety penny getting to 700. You'll have to also have a damn good fuel setup. Maybe a cobra tank, dual pumps, KB BAP etc. Some more guys will chime in and set you up for success. GL!
Soldier GT is offline
Old 08-19-2015, 11:51 PM
2003 4.75l
2003 4.75l's Avatar
Going pro charger I been comunacating with MMR directly so far this set up is there hmmm Isuggestion s however I already have the eldabrocK intake and fuel rails I was going to stick with the that for now from what I have learned about it and was told by the place that will be tuning it to go with 90lbs injectors and yes for sure 373
Old 08-19-2015, 11:55 PM
2003 4.75l
2003 4.75l's Avatar
Will be the 44cc twisted wedge cnc heads and stage 3 cams as of now and yes a lot of money but I don't really care on this build
Old 08-20-2015, 12:01 AM
2003 4.75l
2003 4.75l's Avatar
The fuel system is something I'm fumilurhot on some help with that would be very helpful
Old 08-27-2015, 03:01 PM
oxfordgt
oxfordgt's Avatar
I used stock bore and stroke forged shortblock, patriot stage 3 heads, CMS stage 3 blower cams, TFS intake, Novi 2000R pushing 23lbs and made 700rwhp. There are better heads out now which will make it easier. Biggest problem is belt slip so 700rwhp was pretty much the limit because I already had the best of the best stuff trying to stop the slip.
oxfordgt is offline
Old 08-27-2015, 03:03 PM
oxfordgt
oxfordgt's Avatar
I used 60lbs injectors, sumped tank, A1000 pump, aeromotive rails and regulator and switched it to return style. I sprayed alot of meth so if you don't plan to use meth injection you will need bigger injectors. I was at 70% duty cycle even with spraying meth.
oxfordgt is offline
Old 08-28-2015, 07:58 PM
2003 4.75l
2003 4.75l's Avatar
This helps a lot now debating between the d1 or the f1 pro charger and a bit more about the fuel pump and y the need to change my fuel tank
Old 08-28-2015, 08:01 PM
2003 4.75l
2003 4.75l's Avatar
So far from what I understand I'm on the right track
Quick Reply: 700hp 4.75l am i on the right track
