Ground Check/Battery Cable Replacement
Old 12-01-2015, 08:45 PM
TravisJ33
TravisJ33's Avatar
Default Ground Check/Battery Cable Replacement
So I am having some pretty consistent corrosion around my positive battery terminal. Thinking I want to tighten all the grounds and perhaps replace my battery cable. Couple questions:
1. I am not sure of all the ground locations. I have the workshop manual "Battery Cables Removal" which I believe shows all the ground locations but I am not sure. Are there any I need to check that may not be covered by those instructions?
2. If I choose to replace the cable which one of these (if any) will suffice? Is only one of these the positive cable? Will I need to do anything apart from reattach the grounds and terminal?
http://www.oreillyauto.com/site/c/se...2002&make=Ford
Any suggestions on alternative products and/or strategies?
Thank you.
TravisJ33 is offline
cthomasparr
12-06-2015 09:37 AM
Cali392
12-04-2015 09:01 AM
jrp79
12-02-2015 11:53 AM
SilverBullet23
12-01-2015 05:34 AM
sprog
11-29-2015 08:54 PM
Quick Reply: Ground Check/Battery Cable Replacement
