new heads
Old 06-12-2016, 07:16 AM
chipss36
chipss36's Avatar
Default new heads
getting close to running this baby, stage 2 mhs cams, ported heads, headers, and some other support stuff, cant wait to hear it run.
Attached Thumbnails new heads-13265938_10209669277274418_8936137496260310115_n.jpg   new heads-13245488_10209669281314519_5543828035009938202_n.jpg   new heads-13321996_10209754335800828_608633085842668459_n.jpg   new heads-13394070_10209772616217827_3350352921680824760_n.jpg
chipss36 is offline
Old 06-12-2016, 12:41 PM
Camster
Camster's Avatar
Looking good.
Camster is offline
Old 06-14-2016, 06:07 PM
WJL
WJL's Avatar
Is that a 1998 NPI motor?
WJL is offline
Old 06-14-2016, 06:44 PM
Soldier GT
Soldier GT's Avatar
That's gonna be a nice bump in HP!
Soldier GT is offline
Old 06-15-2016, 11:35 AM
chipss36
chipss36's Avatar
Default mhs?
So got to the point to change oil, filters, and new coolant. ...
Coolent poured directly into crank case, via what appears to be a hole drilled from the chain tensioner oil feed directly into the water jacket under the thermostat, mhs needs to do better than this....took 3 days to find the problem.
http://youtu.be/TOt57NdoWsU
chipss36 is offline
Old 06-15-2016, 11:39 AM
chipss36
chipss36's Avatar
Dont know ? Came in A 2001 gt
But do know he did a motor swap
So not sure.
chipss36 is offline
Old 06-15-2016, 03:43 PM
WJL
WJL's Avatar
I only brought it up because your oil filler tube is on the left side of the motor, same as a 1998 (NPI motor), i think they switched in 99 (PI motor) and put it on the right side, could be wrong.
If it is the NPI like Soldier said you will get a nice bump in HP due to the increased compression ratio and better air flow, good luck
WJL is offline
Old 06-15-2016, 06:20 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
holy crap....id go ballistic.
been in that boat before, will they pay you for new head bolts and gaskets now?
WhiteFoxGT is offline
Old 06-15-2016, 06:28 PM
WJL
WJL's Avatar
Wow that's crazy
WJL is offline
Old 06-16-2016, 08:35 AM
chipss36
chipss36's Avatar
Out of 50 years of building, this was a first, I did see other issues with the heads, one was said cleaned and inspected followers.
One was scored, and the wheel grinds....so I put gt 500 followers in, second was china valve seals, I just think usa made felpro belongs in a perfomance head, to top all this off, I spent a month getting a gasket match perfect, and cleaning up all ports.
The more I think of this the more pissed I get, ya what about . Bolts, gaskets, fluids, and cleaning products I need to get this right, and my "free labor".
Still in shock, no excuse to send a head out with oil/coolent mixing.....just in shock.
chipss36 is offline
Quick Reply: new heads
