spark knock
Old 08-02-2016, 03:59 PM
shaker56
shaker56's Avatar
Arrow spark knock
I have a 2004 4.6 2V engine bored 20 over custom grind cams stock heads just planed ford racing intake BBK 78 mm throttle body and the crank was cut to go with the grind of the cams it is supposed to be a stroked 288 the problem im having is at full throttle it has terrible spark knock the guy that built the engine said it needed to be tuned so I got it tuned at a place in New Jersey they said it is tuned now but I still have the spark knock can the cams be off a tooth im wondering if anyone had a problem like this any help would be appreciated I also tried two colder plugs and only run 93 or 94 octane in it
shaker56 is offline
Old 08-02-2016, 04:52 PM
Z28KLR
Z28KLR's Avatar
Doubt that the cam sprockets are off by a tooth or two. Your problem would likely be a lot different if they were.
There could be a bit more to it, but if you're running 93 fuel and still got pinging at wot then likely spark timing is a bit too advanced. Put stock heat range plugs back in and tell the shop in NJ to put it back on the dyno and make it stop detonating.
Z28KLR is offline
Old 08-02-2016, 06:25 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Sounds like you need a new tuner
WhiteFoxGT is offline
Old 08-02-2016, 09:55 PM
jwog666
jwog666's Avatar
^^^^^^^^^^this +10000000000000
jwog666 is offline
Airridestang
04-16-2017 03:36 PM
crazhrse
09-07-2006 03:06 AM
larrylass
08-06-2006 08:58 PM
Aixtreme89
07-31-2006 09:21 PM
Protraxrptr17
12-20-2005 10:55 PM
Quick Reply: spark knock
