Stash away a new Ford mfg TOB?
Not a bad idea because theyre not that expensive but maybe not necessary. I have the T45 and I havent considered doing that. If you want to gauge how long Ford will make the part, check out the older transmission parts and see if they're still in production. Do you think you will keep the car for a long time?
I'm 64,so I don't know how much of a long time I have. ;-)
On the fence about keeping it for few more years or letting it go this spring.
Not like I'd be getting that much by selling it,no life changer for me,but I'm also probably content with just having my other car.
Probably overthinking it,but I like spares for lots of things.
If you have an extra oem tob, may as well keep it around for the time being. Makes a nice paperwieght, you can throw it at somebody in a fit of rage, or if you hang onto the car then it saves you the money and hassle of buying another one someday.
There used to be a lot of talk on the forums about oem vs aftermarket tob's and how oem is superior in every way. I used the tob supplied with a Spec clutch kit and had no issues for 30 or 40K. Had to replace the clutch setup due to the Spec aluminum flywheel I had installed at the same time back in 2009 failing about a year ago. New clutch (Exedy 400) and Exedy lightweight flywheel.
Went ahead and bought an FRPP tob due to all of the "talk" over the years. Upon comparing it to the one supplied with the new clutch kit, they were EXACTLY the same. Same part # markings on the bearing, same "made in China" on the box. Only difference was one box said Exedy and the other one said Ford.
I suppose all it means is that Ford and Exedy get their bearings from the same supplier, but it does go a little way toward dispelling the "oem or gtfo" bearing talk.
