So there is this green Sensor cylinder thing that goes into the radiator and I need to know what it does and if I can leave it out of its housing area since it gets in the way of the procharger inlet pipe because it's housing is right below it. I included pictures below.
Now that I look closer at it, I know exactly what it is, Its not the level sensor,,,
It is the resistor for your low speed fan operation,,, and I would try to rewire and relocate it so your low speed fan operation works.
I'm not going to disconnect it, you think it will still work if it's not in the hole? Because I was on planning to secure it to the coolant tank support.
Yea it will work, it just lowers the voltage to the fan when the low speed relay comes on. With out it the car may cycle the high speed on and off constantly.
