98 Mustang GT 4.6L speed sensor won't fit
The speedometer in my 98 GT intermittently stops working. Odometer and tach is fine. Pressing the trip reset button will get the speedo working for a short while but it was not accurate. I purchased a new speed sensor from an Autozone. It looks exactly like the one on the car but when I attempt to install it, the part will not fit. The plug or barrel portion is just a hair to large to fit in the cylinder. it is so close. I even tried getting a second part just in case the first was defective but no go.
I am at a loss. Any ideas?
I would yank the cluster out and have it gone thru. Id assume thats the best spot to look based off your description. If pressing the trip/reset will get the needle moving, its probably an internal fault at the cluster itself
