whats the better move?
Old 12-19-2005, 11:55 PM
XxphantomsnypzxX
XxphantomsnypzxX's Avatar
Default whats the better move?
Pi swap, camshaft on my 96 gt or someone suggested finding a 99-04 engine and just go with that any suggestions?
XxphantomsnypzxX is offline
Old 12-20-2005, 12:02 AM
97stanger
97stanger's Avatar
Default RE: whats the better move?
you're better off doing the pi swap with the cam...throwing a pi swap in a non pi car will be faster than a 99+ pi car stock vs. stock because of the compression difference
97stanger is offline
Old 12-20-2005, 12:27 AM
*Blk_96_Stang_GT*
*Blk_96_Stang_GT*'s Avatar
Like he said the swap and cam will give you more hp than a stock PI engine, and it would be cheaper unless you found a 99+ with a lot of miles on it, but go with the PI swap and cam.
*Blk_96_Stang_GT* is offline
Old 12-20-2005, 12:39 AM
demon_head
demon_head's Avatar
ORIGINAL: 97stanger
+1
But.....If you're planning on doing a s/c down the road, the higher compression from the PI swap wont really allow you to run high boost levels.....if you're lookin' to stay N/A then the PI swap and cams will do the job.....especially with a port and polish on the heads, and long tube headers thrown into the mix.....
demon_head is offline
Old 12-20-2005, 02:49 AM
Slick97gt
Slick97gt's Avatar
these cars have CAMS, not a cam
the pi swap with a set of cams is going to make quite a bit more power then the stock 99-04 motor, and will probably entail about the same or less work then a motor swap.
Slick97gt is offline
Old 12-20-2005, 10:40 AM
nanaki
Retired MF Moderator
nanaki's Avatar
ORIGINAL: *Blk_96_Stang_GT*
what are you smoking? you can get a 99+ engine with low mileage for CHEAP. i still say, if you got the time and money, swap that engine out and get a 5.4 thrown in. ebay
nanaki is offline
CS2007
06-25-2019 09:45 PM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
Quick Reply: whats the better move?
