Shorty or Longtube
Old 01-21-2004, 08:30 AM
DW-03GT
DW-03GT's Avatar
Default Shorty or Longtube
Originally Posted by tjs57tpi
ive heard headers actually make it so u dont have enough backpressure and lose power for the mod motor, is this true?
</P>
I don't know why people say that. Not even close to being true.</P>
DW-03GT is offline
Old 01-21-2004, 08:46 AM
karma279
karma279's Avatar
Originally Posted by DW-03GT
Originally Posted by karma279
</P>
Oh yeah, a good set of shorties will improve performance. Anyone that looks at those crimped stock headers on these cars and says that aftermarket shorties don't offer improvement is full of crap. Don't get me wrong, buy long tubes if you can.... but a good set of coated BBK equals will improve your HP. </P>
</P>
Have any #'s to back that up? I've yet to see any.</P>
</P>
Hell, you don't need #'s. Just look at the stock headers on a Fox, common sense will tell you a nice set of equal shorties will improve flow. Improved flow=increased performance. </P>
karma279 is offline
Old 01-21-2004, 08:55 AM
DW-03GT
DW-03GT's Avatar
ET's drop by 1 to 1.5 tents and dynos's show 10-15 with long tubes, the stockers are not that bad. Take a look original manifolds fromthe 60's and 70's , they are bad, thats why you can gain half t 3/4 secconds with headers on old cars
DW-03GT is offline
Old 01-21-2004, 09:28 AM
karma279
karma279's Avatar
I didn't notice this was on a 4.6 section of the forum. I dunno much about the stock headers on those. All I can say in on a stock Fox they are utterly crimped, and putting on a set of aftermarket equal shorties will increase performance.
karma279 is offline
Old 01-21-2004, 11:43 AM
DW-03GT
DW-03GT's Avatar
yeah, different beast.
DW-03GT is offline
Old 01-21-2004, 12:01 PM
Craziness4fun
Craziness4fun's Avatar
If I'm not wrong I believe you loose some low end torque... Which you barely use anyway. So bye low end torque hello powere everywhere else!<IMG src=smileys/smiley3.gif border="0"></P>
Craziness4fun is offline
Old 01-21-2004, 12:25 PM
Glengemen
Glengemen's Avatar
The shorties will give you power way up top, and will drop the low end torque. The long tube ones will do exactly the opposite. Long tubes are better for street usage. The reason for this is that long slim tubes will increasethe velocity of the gas. The only real downfall of the design is that at higher RPM they will run out of flow causing your power to fall off. The shorties wont have the velocity untill higher RPM. In retun though, they dont kill top end like the shorties do. On built engines a stroker will want long tubes and a destroked engine will want shorties. It is just a question of where do you want your powerband to be.
Glengemen is offline
Old 01-21-2004, 12:35 PM
DW-03GT
DW-03GT's Avatar
</P>
</P>
??? What do you think gets you out of the hole? Top end torque?!?! Low end torque is your freind. </P>
The whole "you loose torque" is simply not true. It may be moved up a few hundred rpm but you don't loose any. There may be a few incidents where that has happened but it's difinatly not the rule. If you were running 2.5" zoomies or somthing like that maybe, but not with the small tubes that are availabel for 4.6's</P>
DW-03GT is offline
Old 01-21-2004, 02:55 PM
tjs57tpi
tjs57tpi's Avatar
the only reason im goin with shorties is so i can swap mid pipes for inspection, but u think if i bought a set of JBA shorties i would feel a nice increase?</P>
tjs57tpi is offline
Old 01-21-2004, 04:43 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Shorties are just fine, I made a huge post about this before.</P>
</P>
http://www.seanhylandmotorsport.com/shm_freq.shtml</P>
Dan04COBRA is offline
Quick Reply: Shorty or Longtube
