12's in a 2v on a budget...vid up!
Old 12-29-2006, 05:57 PM
  #21
rbstang
rbstang's Avatar
Default RE: 12's in a 2v on a budget...vid up!
im guessing you used slicks.. and not like MT drag radials.
rbstang is offline
Old 12-29-2006, 07:32 PM
  #22
BadBob99GTConv
BadBob99GTConv's Avatar
So you think Im close to high 12's then with MT's and cooler weather? I ran mid 13's in 94 defree weather driving to the track in Louisiana.
BadBob99GTConv is offline
Old 12-29-2006, 08:10 PM
  #23
mylongvictor
mylongvictor's Avatar
Slicks seem to take off almost a whole secound off your time..... I've used them once unaware of their grip potential and almost broke my neck! lol....
But my Stang has to peform as a daily driver and I don't have a flat bed to trail my car to the track and I'm too lazy to change out the tiresfor skinnies/biggies.....
mylongvictor is offline
Old 12-30-2006, 02:48 AM
  #24
Texas_Hot_Rods
Texas_Hot_Rods's Avatar
ORIGINAL: rbstang
Yes, since this was a MMFF shout out and we needed the best times possible, we used brand new M/T slicks. You can see them wad up in the pics and vid, and that is how you yank the wheels and rip 60 ft's vs sticky street tires with stiffer sidewalls. You can have similar performance with ET streets and drive it too and from the track legally, but if you want the best track times, go with full slicks.
You should be able to dip into the high 12's with better weather and slicks if you are runing 13.40's in the heat. Checksuspension mods and the free stuff I posted earlier and practice driving, you get your timeslip!
Good Luck
Brian THR
Texas_Hot_Rods is offline
Old 12-30-2006, 03:36 AM
  #25
ZW99GT
ZW99GT's Avatar
Thats a hell of a set-up right there. Eventually, I'm gonna go with that exact suspension.
ZW99GT is offline
Old 12-31-2006, 04:29 PM
  #26
dubarado
dubarado's Avatar
I don't think I'd want to remove weight just to lower my ET... and then re-install it...
dubarado is offline
Old 01-01-2007, 02:01 AM
  #27
Texas_Hot_Rods
The idea of removing weight to lower your ET's was simply for 1/4 mile times as stated. If you run the track on slicks, would you not take them off to drive to work and back? Same principle. Weight loss at the track is an easy and FREE way to reduce ET's, hence the post title, 12's on an budget.
Old 01-01-2007, 03:11 AM
  #28
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: Texas_Hot_Rods
Yep, HP means nothing without suspension and weight reduction. It took me awhile to figure mine out. EXCELLENT thread, Brian.
code3GT is offline
Old 01-02-2007, 02:44 PM
  #29
mikev08826
I ♥ Acer
mikev08826's Avatar
Nice car/thread.
Wouldn't that kind of grip with the brand new slicks wreak havoc on the stock spline and stock t-45? I'm concerned about running MT drag radials for that reason...
mikev08826 is offline
Old 01-02-2007, 03:08 PM
  #30
suzukidragracer
suzukidragracer's Avatar
Was that englishtown or atco in the vid?
That sounds like Eddie Kraweic, the track manager at englishtown, in the background.
~Vince~
suzukidragracer is offline
