Quote:
Originally Posted by jdsm-boy
yeah im just looking for the better quality product nomatter the price and best hp gain....also what about pullies what the best to use???
From the looks of your name..you look like a converted noodle car owner.. so ill treat you as such...
contrary to popular belief bigger is not better in terms of tb size. you want to match up to what your car has on it. 70mm is recommended by all manufacturers for an n/a car. These are engineer who are smarter than most ppl on the site that recommend 75mm just because the dyno gains are 2-3hp higher. intake air velocity is more important than 3peak hp..
as far as pulleys get steeda and steeda only. most other companies use piggyback pulleys which are a no go.
Accufab is going to be your best bet for looks+performance. I would also look for it used... but if you want new you can also go with trick flow or C&L
When you buy mods for your car piece them together carefully, you will maximize your gains by doing that.
