tb vs plenum
Accufab t/b & plenum saw a 12 rwhp on my 02 Gt..
The C&L will squeeze out maybe 1-2 more hp, but the accufab is a great looking piece.
Also, the t/b is a much better pieces than stock and you will notice instant improved throttle response
LOL I was being sarcastic dorks
The larger the passageway you create for the air to flow through the more volume of air you'll be able to push through it. Is it worth the hp/dollar ratio? Probably not unless you go with an FI setup. When building your car on a budget it's not necessary to always go with the best (i.e. Accufab). Professional products, C&L, Trick Flow, and also BBK make decent TB/Plenum combos. For a price difference of $200 between accufab and PP I don't see the logic in going with Accufab, unless you're trying to squeeze every ounce of toothpaste out of the tube. JMO
Gary Ugarek
08-26-2015 08:41 AM
