Guess what she will make this time on the dyno
Well my car made 15 rwhp per pound of boost so if it makes 17 psi I was thinking 550 if it makes 20 I am thinking 600
Not with stock heads, intake and NA cams I doubt. Are you running an 8rib? Boost is just a measure of restriction. I have a pretty free flow motor with the ported heads and the blower cams. Plus I have LT's and a full 3" exhaust dumped. Plus with 20 psi I would use race gas or torco.
his cam is way too small to make 550+, at 17PSI your going to be choking up on heat from the stock heads, they simply aren't going to flow well enough to get you above maybe 540rwhp.
If your heads were to flow better, and you had bigger cams, I'd say 640 with a T-trim, still at a true 17PSI Manifold pressure.
But with your mods, 17PSIG is just going to be from a restriction. Sorry to rain on you's parade, but aside from the stock heads/cam, that's close to my setup, ie T-trim at 16PSI, T-56, etc
we are real close in mod s tirm http://modularpowerhouse.com/forums/...ad.php?t=37090
then t trim http://modularpowerhouse.com/forums/...ad.php?t=54536
we will see I will let you guys know
I will guess 530rwhp and lots of belt slip. The car is not set up right (for a vortech)to make high boost and high numbers. The overdrive crank pulley will help but there will not be enough belt wrap on a vortech set up to handle 17-18 lbs. With stock heads and crap cams (for a blower) your power is going to really be killed.
