How do I data log?
How do I data log?
How do I data log? I'm a complete newb at this. I have a Xcal 2 and a laptop with the software on it. I'm still getting a small intermittent hiccup at cruise in the lower RPM's.
I would like to datalog stuff like maf transfer and voltage, TPS voltage, front 02's, fuel pressure at cruise, FRPS, cam and crank sensors, and the coil packs.
I also have another question concerning a user parameter in the Xcal. It says I'm able to lower and raise the global spark it certain rpm ranges. I feel the hiccup might be helped with a little more timing in the 2-4k range due to my heads having no swirl damns and not burning the air fuel mixture well enough in part throttle cruising conditions. How will this effect my WOT tune?
Sounds like you are having the same problem I am. Between 2k and 3k rpms I have a lack of power and sounds like a miss. I get popping in the exhaust between shifts and during decel only between 2k-3k. I have data logged it and it looks like timing is dropping between or too low during those rpms. I have sent it to my tuner and he keeps trying to send me different tunes with more fuel and that only makes it worse. I think I'm about to go to a new tuner if mine can't figure it out by the end of the month.
But to data log just plug in the tuner, select data log, select the PIDs out want to monitor, save the set up, start the car, start the datalog. Then to view it plug in the tuner to your laptop, open livelink, select file then import ....(can't remember all of it) then lelect datalog0 and it will pop up.
The funny thing is it was great before the tune because the new intake leaned it out a little. Plus it's every so slight.
I think I might add more timining between 2-4k and just stay out of wot and see if helps the cruise.
Well I looked over my data log again and found out it is tuned in open loop during those settings. No wonder I'm having all these driveability problems. I got sent new tune that changes the open loop point. My tuner told me he tuned it that way because my boost comes on so fast the switch from closed to open wouldn't be fast enough and would run lean when I stomped on it.
I am going to dyno speed in Memphis the first week of may to get it retuned correctly.
What would he do with a twinscrew?
I been running an SC on this car for about 6 years and never had a problem until recently and it's mild enough I could live with it but I don't want too lol.
That's very interesting, I have zero problems, but my boost doesn't come on that quickly. You guys probably see Max PSI by 6200-6400. I don't until 6800, and it probably builds alot slower too (I believe I am running less boost than both You and OX)
Then again, it might just be that I'm running a different ECM. I'm not sure. That's kind of a weird problem to have, especially two different people with close to the same setup.
Hope you get it sorted out man
