Trick flow cams duration 264/264 lift .550/.550 review??
Old 08-01-2009, 10:06 AM
H0SS302
H0SS302's Avatar
Originally Posted by PDowdy1
yeah, whats your opinion on how it would sound long tubes with a muffler delete. cause right now the car sounds mean. but i dont want overkill ya know.
HAving no mufflers is a pretty ghetto way to do things. Buy some longtubes and buy some mufflers.
H0SS302 is offline
Old 08-01-2009, 04:00 PM
PDowdy1
PDowdy1's Avatar
yeah i like the sound its clean thats why i did the delete.
i will probably just get long tubes
PDowdy1 is offline
Old 08-01-2009, 04:23 PM
avlon06
avlon06's Avatar
o/r x and LM2= sex
avlon06 is offline
Old 08-01-2009, 06:30 PM
boduke0220
boduke0220's Avatar
Not true, if you have a built motor the 19lb/h injectors are not gonna cut it.
really? i thought you only needed them if you were in the high 300 hp range?
boduke0220 is offline
Old 08-01-2009, 09:33 PM
H0SS302
H0SS302's Avatar
if you build your motor you better be over 300 hp or you did it wrong lol.
H0SS302 is offline
Old 08-01-2009, 09:48 PM
boduke0220
boduke0220's Avatar
ohhh were talking FI built..i was thinking N/A lol
Old 08-01-2009, 10:13 PM
H0SS302
H0SS302's Avatar
I am talking about n/a.. if you build your motor meaning h/c/i you better be over 300... or you did it very wrong.
Shoot even just adding stage 2 cams on a full bolt-on car is pushing the injectors a little to far IMO.
H0SS302 is offline
Old 08-01-2009, 10:16 PM
GTRACER88
GTRACER88's Avatar
you dont need injectors untill your supercharged or N20'd.
Not true for this either.
GTRACER88 is offline
Old 08-01-2009, 10:31 PM
mrtstang
mrtstang's Avatar
Even if the stock injectors can handle over 300 rwhp, doesn't mean they're the best bet. At that point they may be at 95-100% cycle duty, which is not ideal.
mrtstang is offline
Old 08-01-2009, 10:52 PM
PDowdy1
PDowdy1's Avatar
yeah i will eventually replace the injectors after im stage 2 cammed im just going stage one now.
How hard is install me and my buddy are suppose to be doing it?
PDowdy1 is offline
Quick Reply: Trick flow cams duration 264/264 lift .550/.550 review??
