a 2v with a few good mods, gears, and a driver is capable of 104, 105, 106mph trap speeds...
This with street tires, and a 2.0 60ft is good for low 13s...
with good tires, and a good launch, high 12s...
My personal car went 13.2 at 106 with a 2.0 60ft.....
__________________
"If people are calling BS, you know your doing something right."
11s with no 3rd gear.
http://s104.photobucket.com/albums/m199/blackonblacksls/?action=view¤t=MVI_1493.flv
^i think someone had sex with your car the night before you took it to the track because those are some happy times there buddy... u close to sea level? not sayin i dnt believe u at all just way better than like 95% of people with more mods
__________________
Cia, 75mm TB, plenum, ford racing shorties, catless H, flows, alumn DS, king cobra clutch, short shifter, 4:10s, predator
106 is not impossible with a bolt on gt... add in a 2.0 60ft and a few power****s and low 13s come pretty easy......
add tires and a 1.6 or so and high 12s can be done...
__________________
Given the right conditions i can see it happening. It would be pretty rare though. With just bolt ons and gears my best is a 13.3 @ 104 with a 2.0 60ft, and best trap was 105. This was all done in 80 degree weather too.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
Definately, if you got the tires and suspension to go along with the gears you'll run as long as your not too shy with it. Right now as is I've ran a 13.519 in the heat of summer. With the new suspension going on soon and november in jersey I'm hoping for a 13.1. For a bolt on car it's all about getting it to hook up.
Do you have no top end with the 1.6 60' to get those 12s? My camaro cuts mid 1.6 60's and is around 11.60-.70s. I was cutting 2.0 60's with 14.0 times with just a catback.
By the way you would probably hit 13.70s at best.
A bolt on GT doesn't flow enough or rev high enough to run that fast. If you have heads and cams, then maybe those high 11s are possible if you can drive the balls off of it. BTW, what's done on your camaro?
