FOX, LIVERNOIS OR TRICK FLOW
Old 10-31-2009, 12:16 AM
Soldier GT
Soldier GT's Avatar
Default FOX, LIVERNOIS OR TRICK FLOW
Looking to upgrade my heads after I buy the S/C (Procharger). I heard alot of great things about the new Trick Flow heads but was also told to look into the Livernois and Fox Lake heads. Out out of those three which would be the best setup for a Supercharged 2V? Thxs guys, any help would be appreciated..
Soldier GT is offline
Old 10-31-2009, 12:35 AM
Sxynerd
Sxynerd's Avatar
FL or TF.
Sxynerd is offline
Old 10-31-2009, 12:46 AM
Soldier GT
Soldier GT's Avatar
Would you reccommend that I get the heads before the s/c? Also what numbers should I be looking at (rwhp) with just the heads installed and my current set up?
Old 10-31-2009, 12:49 AM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
I would say ~300rwhp with just the heads.
WannaBeGearHead is offline
Old 10-31-2009, 12:54 AM
Soldier GT
Soldier GT's Avatar
That's about what I expected? I've decided to go with the Procharger next year and then maybe the heads (Trick Flow) a couple months later. That shoud put me right at the 400hp mark shouldn't it?
Old 10-31-2009, 12:58 AM
Sxynerd
Sxynerd's Avatar
There's no point in only getting heads; cams need to be bought at the same time in order to take any advantage of the better flowing heads. If you know you're going to be going to go the S/C route then get a set of custom blower cams like CMS 2.5 blower cams. I would get the S/C first.
Sxynerd is offline
Old 10-31-2009, 12:59 AM
WannaBeGearHead
Go Texas!!!
With just the s/c it should yes
Old 10-31-2009, 01:25 AM
02Stang89
02Stang89's Avatar
In the spring Im getting Trick Flow heads ported through Fox Lake. Its not cheap but for 500 bucks more Im gunna do it. My future plans are for twin turbos. I agree with sxynerd and say that you should get cams. Im getting Crower Stage 3 Turbo cams.
02Stang89 is offline
Old 10-31-2009, 01:28 AM
Sxynerd
Sxynerd's Avatar
If you want a good set of turbo cams, I've seen some amazing numbers come out of MPH's custom grinds.
Sxynerd is offline
Old 10-31-2009, 08:37 AM
02Stang89
02Stang89's Avatar
Ok Ill have to check those out. Thanks man
Quick Reply: FOX, LIVERNOIS OR TRICK FLOW
