Everyone with a vortech/procharger/whatever get in here..
#21
Gas pressure, and boost pressure. You already have an oil pressure guage in your car, and if you run braided ss lines to the blower, you have absolutely no reason to worry about it.
Boost and Gas pressure can help diagnose almost anything you will run into, problem wise.
#23
hell get oil pressure and fuel pressure. You wont know boost, but you will at least know if there are some serious mechanical failures.... which I would think is up there on the "important" list. Dan can tell you how many lbs of boost you are running.... it doesnt change over time lol
#27
#30
http://www.lethalperformance.com/99-...-gauge-p-30021
Wonder if i need to buy anything else? other than the pod obviously.
Edit..nvm apparently it comes with a cable that i plug into the OBD II Port..hmm might just get that! thanks Teej!
Edit again.. looks like if i want a/f or boost i have to buy seperate cables..hmmmm
