Is this bad for my car? COME IN QUICK!
So tomorrow i am going to a members house on here to slightly cut my springs all around to give me a little bit more of a drop. (linear rate springs are being cut)
I jacked up the rear passenger side of my car so that the weight transferred to the front drivers side wheel. I than had my dad sit on my engine bay and i gave him a 50lb dumbbell to hold.
Staying with me so far?
Doing this gave my car EXACTLY the height that i wanted the front end to be. It sat at around 25.5" from the ground to the fender. It looked like pure SEX.
ANYWAY, i figured let me turn the wheel to see if i get any rubbing on the fender or the fender liners on the inside of the wheel... Guess what? The wheels rub the liner upon full turn.
As some of you know, some mustangs are ghey and their front wheels sit back in the fender (nearly an inch closer to the sideskirt) as opposed to being right in the middle with equal fender gap from the front bumper to the wheel to the side skirt
My car seriously looked f*ckin sick with the drop i had on there. It wasn't "too low" by any means. It looked clean and it was a big improvement that would really finish off the car compared to the stance i have on there now.
So my question is this -- Should i just drop the car tomorrow like i had planned for the last couple of months and not worry about rubbing on the fender liner upon full turns and possibly large bumps? Or is it bad/annoying to drive around like that?
Is there a cheap fix to this madness that will put my wheels in the center of the fenders?
CLIFF NOTES
1) My car sucks
2) If i drop the car, my front left tire will rub the inside of my fender liner upon full turns and possibly large bumps where the shocks compress
3) What should i do? Drop it anyway and rub? Or wait?
CLIFF NOTES
1) My car sucks
Come to think of it, don't all of you guys with 275/40's or equivalent rub 24/7?
Worst thing that can happen is the tire will rub through the fender liner correct?
Here are some pics of what i was doing tonight hahaha. I need to get a f*ckin life.
And this is full turn. It hits in one spot kinda firmly.. It's not a graze, but it's not really pushin it either.. Just rubbing firmly. Hard to see =/
and this is what my rear would look like slammed
Obviously i'm not going that low in the rear. Good thing my fenders are rolled bc i didn't realize how high i had the tire up there..
And if you look at the pic of me rubbing, i think that the spots where the fender liner is dark is where i am hitting... I put tire shine on the tires today so that much be it.. Idk what else those black spots would be...
I run 275's on the front and no issues. I didn't have my rear fenders curved (in the rear) and the edge of the fender fu**ed up my tires. HP you should'nt have a issue with the front tires at all.
I'd say drop it like it's hot and worry about the aftermath if need be. That or get a tubular k member from MM and you take care of both the offset wheel in the fender and you get front coilovers so you can adjust your ride height from slammed to 4x4. Lol
And as far as the wheels being that far back in the wheel well, my wheels are the same way. I bet you if you take side shots of all your cars you'll find the same thing. You don't really notice it til you take some side shots. That why MM's k member can move the tire forward 3/4" with standard offset front control arms and then with offset control arms get another 3/4" put of it. There is plenty of forward movement in the front fender wells f our cars.
